Originally Posted By: Tom NJ
Originally Posted By: nthach
I know, bumping an old thread. I would imagine an aviation turbine like BP/Eastman 2380 or Mobil Jet Oil II might hold up better in a sludge monster/ring coker Toyota than a PCMO...
Not a good idea. Much too thin (5 cSt @ 100°C), no detergents, no EP, no dispersants, no anti-rust, and too much phosphorus.
Tom NJ
Correct, 2380 is too thin, it's considerably thinner than even the newest 0W-16 oils and possibly thinner than the newest 0W-8 oils. I work with 2380 and it is clearly very thin. It works well in many turbine engines, however there is a newer family of high thermal stability turbine oils that perform considerably better under extreme heat. In other words, 2380 is really not great in high heat situations.
Our Eurocopter EC135 with the Turbomeca Arrius 2B1_A1 engines do tend to coke the aft bearing housing with 2380. So I've switched to 254 oil.
Remember that the bearings in turbine engines are very high grade ball or roller bearings. Some are lubricated via a pressurized system that simply provides a spray or mist to the bearing. Every once in a while, I come across a conventional sleeve type bearing on an accessory drive. Guess which bearing fails and is generally replaced, via service bulletin, by a more robust roller or ball bearing setup?
