The Trans fluid on my Fusion Sport is maintained at the ECT because coolant is routed to the top of the trans before the external thermostat. Mercon LV routinely runs at this temp, whether it is the 6F55 or 6R80. On my 2014 sHO, it doesn't use this cooling setup and instead relies on an external thermostat only. So my TFT can drop to 160 to 180F in the winter time.
On the police and PP ecoboost PtUs, the cooler reduced the temps by like 20F to 40F, running about 250F or higher. I read Ford had a change in 2014 and in 2015 related to the thrust washer on some idler gears inside the PTU. Seeing how there are still model year 2016s with PTU failures, those fixes didn't work. I read Ford had a change in June 2016 that prevents the gears from walking into the case. So the proof in the p udding would be to see if there are any PTU failures for MY2017 and beyond.
