Originally Posted By: zrxkawboy
Originally Posted By: ford46guy
Running cooler is good and bad, less wear and tear on the engine but probably more fuel used.
Actually, running cooler results in more engine wear.
I will only use OEM or Superstats. In your case, I'd sure try a Superstat and see what happens.
I think that is a claim which could use some greater detail.
There is nothing wrong with running at the lower end of the design operating temp range.
The oil is perfectly viscous. The engine parts are sufficiently expanded.
Please support your opinion if you have time.
Thanks
Thanks
