Originally Posted By: SnowDrifter
Since this thread is turning into false info about you shouldn't apply dielectric grease to electrical connectors, I'm going to nip this in the bud now.
Dielectric grease is designed specifically for electrical connections. It's purpose, to keep moisture and dirt out, It's a mechanical barrier. The reason it's used is if you were to use a conductive grease for electrical components, you would incur leakage current between electrical contacts, leading to electrolysis and corrosion. It keeps moisture out for the same reason. The stuff is designed specifically FOR electrical connections. Don't get hung up on the naming convention.
Uh huh...
Didn't read all of the responses, huh???
Excellent argument, expand on that for me.
Really, only a couple of people were ignorant in the use of dielectric grease. Several people subsequently corrected these members. Afterward, you came in and said:
So, you were not responding to the trend of the thread...
