Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
Is arming teachers the answer?
by ZZman
02/21/18 06:45 PM
Another ATF question... I aplogize
by bardos
02/21/18 06:12 PM
To Seafoam or Not?
by Marco620
02/21/18 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
02/21/18 05:50 PM
Castrol Edge 0w40 Formulation Change
by Tmaslar
02/21/18 05:41 PM
Another Brake Fluid Flush Question
by artbuc
02/21/18 05:19 PM
Preventative Care ?
by maverickfhs
02/21/18 05:14 PM
my best deal ever
by 93cruiser
02/21/18 05:08 PM
Motorcraft fl1a cut open 3yrs oci
by rollinpete
02/21/18 04:05 PM
Slapped my FilterMag onto a Fram Ultra
by ZZman
02/21/18 03:59 PM
Toyota OEM Oil Filters: 5 for $15 or 10 for $30
by NYSteve
02/21/18 02:37 PM
Need Oil Change Advice
by Fulgore
02/21/18 12:51 PM
Weather
by bigj_16
02/21/18 12:27 PM
2013 Ford Focus 2.0 GDI: OE Spark Plugs, 94k miles
by Nick R
02/21/18 12:26 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
131 registered (2004tdigls, 4WD, 901Memphis, 14Accent, AdditiveOCD, 15 invisible), 1669 Guests and 100 Spiders online.
64253 Members
65 Forums
278513 Topics
Page 1 of 2 1 2 >
#4520834 - 09/20/17 12:30 AM MSDS: Which Brake cleaner is better of the two?
tompumped Offline
Loc: ny
https://www.sherwin-williams.com/document/SDS/en/764423182094/US/
file:///C:/Users/m/Downloads/SDS%20E%20-%20PY4003.pdf
I actually spent two hours researching different brake cleaners and I can't find a definitive answer on which is the best 5 gallon purchase to make so i'm going with these two. I have no idea how to make the determination of which would be the better choice.
I've spent a lot of money over the years on the cans I just bought a zep sprayer, next is the fluid. I have no idea which will clean better of the two. Honestly i've seen no difference in cleaning power with all the different brands I used.
Pic is the sprayer I just purchased. Thank You
#4520835 - 09/20/17 12:32 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
tompumped Offline
Loc: ny
People seem to think it's way overpriced for the sherwin williams one since it's naptha and ethanol. If it cleans good I don't care about the price. If it's less harmful that's also a plus. I rarely wear gloves when handling parts/rags soaked in brake clean. I might start wearing them honestly.
#4520839 - 09/20/17 12:57 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
Linctex Online   content
Loc: Waco, TX
I just use acetone or lacquer thinner, whichever is cheaper.
Most any solvent will work, so just go with what doesn't cost so much.
#4520840 - 09/20/17 01:00 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
Colt45ws Offline
Loc: Central Washington
I go though a metric [censored] load of the stuff, so I just buy what is cheap. Ive never had brake cleaner not do the business.
I just make sure its non-chlorinated (Since I sometimes use it to clean before/after welding) and I buy 6 or more of them.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4520841 - 09/20/17 01:01 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
Ducked Online   content
Loc: Taiwan
Dunno about OF the two, but water is better THAN the two, and beats them hands down on price, availability, and toxicity.
Edited by Ducked (09/20/17 01:02 AM)
#4520879 - 09/20/17 02:20 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: Ducked]
Billbert Online   content
Loc: California
The problem is that water will not degrease worth a darn
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
#4520880 - 09/20/17 02:27 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
Dave9 Offline
Loc: Cincinnati, USA
Water? lolGTFO
It's only slightly worse than air, which is even cheaper.
#4520950 - 09/20/17 06:57 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: Billbert]
itguy08 Offline
Loc: Somewhere
Add a little Dawn. Don't know what's in that stuff but it degreases awesome.
#4521011 - 09/20/17 08:29 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
Rolla07 Offline
Loc: MTL, CANADA
I find chlorinated works better.
2007 Corolla Red Pearl 151k miles
Castrol Magnatec 0w20 & Napa Proselect
#4521039 - 09/20/17 08:57 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: Linctex]
Bgallagher Offline
Loc: Boston, MA
Good idea. How do you do it? Sprayer? soak a rag?
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4521554 - 09/20/17 06:42 PM Re: MSDS: Which Brake cleaner is better of the two? [Re: Billbert]
Loc: Taiwan
I don't find that much of a problem, since I don't find my brakes get greasy, though boiling water with detergent in it does remove some old grease from the backing plates.
My brakes get dusty, and the problem is that brake cleaner will not de-dust worth a darn.
If they were significantly greasy I'd think that would be a problem that could not be addressed by a wee squirt of brake cleaner
#4521566 - 09/20/17 06:48 PM Re: MSDS: Which Brake cleaner is better of the two? [Re: Dave9]
Loc: Taiwan
Originally Posted By: Dave9
Water? lolGTFO
Air isn't free. You need a compressor, and then later on you might need expensive medical care.
#4521612 - 09/20/17 07:44 PM Re: MSDS: Which Brake cleaner is better of the two? [Re: Ducked]
Loc: Taiwan
and a funeral....but OK, you'll need that eventually anyway.
#4521795 - 09/21/17 12:11 AM Re: MSDS: Which Brake cleaner is better of the two? [Re: tompumped]
Colt45ws Offline
I dunno. Eveything Ive ever hosed down with brake cleaner ends up pretty clean. And yeah, it melts grease like a torch to a stick of butter. I must go through at least like 12 cans a year or more.
I also have used it in a pinch as point defense against WASPS, since it melts their wings and they fall out of the sky.
Edited by Colt45ws (09/21/17 12:13 AM)
-Colton
#4522536 - 09/21/17 06:57 PM Re: MSDS: Which Brake cleaner is better of the two? [Re: Ducked]
tompumped Offline
Loc: ny
I just wanted to know which would be the better of the two. I'd try other solvents but at times i've sprayed it all over everything under the hood to remove brake fluid. I'm not sure if it would be ok with other solvents. Degreasing an engine you can't control where it goes sometimes. There is nothing better for removing oil in hard to reach places.
I mostly use it to remove oil/grease, or clean guns.
Water? lolGTFO
Thank you for your valuable input, be sure to de-dust your brakes monthly.
I'm sure it's going to blow up in my face. I bet it happens all the time, they probably sell them just to maim with the hope of death.
Page 1 of 2 1 2 >
