Yes, this is pretty much all I use and they're fine. Just have'em load tested as that approach the 4-5 year mark. AAP(all stores) load tests for free and gives a printout which shows the condition of the battery. Other auto parts stores such as AutoZone only show, GOOD or REPLACE when they load test.
Quick story:
Had my battery loaded tested at AAP and it showed GOOD w/ CA/CCA readings with other info as well. Went across the street to AutoZone and had them load test the same battery only to have the AZ loat test show - REPLACE BATTERY! NO printout and no explanation.
Quick story:
