Originally Posted By: Shannow
Apparently 120F (50C)...so if viscosity is the limiting factor, then 40cst is it...IF it was designed to be damaged on anything other than 5W20.
Originally Posted By: rooflessVW
Has anyone claimed damage?I could see the system not working correctly with an oil that's too thick. It is a hydraulic system, after all. A weird idle or CEL wouldn't be outside the realm of possibility.
No one is talking about "damage" here. The system is designed to operate correctly on 5W-20 oil that meets or exceeds Chrysler Spec. MS-6395. Anything thicker interferes with proper operation of both of these systems. This is a proven fact. As far as any actual engine damage.... If it does happen, regardless of the reason why, and you have the wrong oil, (read thicker), in the engine, your warranty will be void.
And the real question to be asked here is..... Based on all of this, just what is it you think you are gaining by running thicker weight oil? Over everyone else that uses the factory recommended weight lubricant? Just what is this mystery advantage you think you are capitalizing on?
