Yet another M1 0W-20 grade flavor!
by fdcg27
02/25/18 07:40 PM
The Winter Olympics
by BlueOvalFitter
02/25/18 07:23 PM
Enchilada casserole
by car51
02/25/18 07:21 PM
John Force Crashes at Phoenix!
by KneeGrinder
02/25/18 07:11 PM
Need floor jack that can use Pinch Weld adaptor
by MI_Roger
02/25/18 07:10 PM
The new Champ ST9688 is fat like the 3593
by slacktide_bitog
02/25/18 07:10 PM
Do you drink milk regularly?
by Reddy45
02/25/18 07:05 PM
What Is This Symbol?
by BlueOvalFitter
02/25/18 05:29 PM
Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
114 registered (andyd, antonmnster, AV8R430, asiancivicmaniac, 2015_PSD, 901Memphis, 12 invisible), 1754 Guests and 95 Spiders online.
64288 Members
65 Forums
278797 Topics
Page 1 of 2 1 2 >
#4515465 - 09/13/17 06:37 PM PP Euro 0w-40 2016 BRZ 5,278mi OCI
cueball89 Offline
Loc: NY
Follow up UOA, viscosity sorted itself out after another 0w-40 refill. Farthest right analysis is Pennzoil 0w-20.
#4515471 - 09/13/17 06:42 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
dparm Offline
Loc: Chicago, IL
Curious why you moved up to 0w40. The results don't look much better, if at all, versus the 0w20.
I think you could dial it back to something lighter, assuming it maintains oil pressure under the hard cornering of autocross. If you are concerned about the wear from WOT at autocross, maybe get one of the more stout 0w20s like Motul 300V or Red Line.
2017 Chevrolet Corvette Grand Sport
#4515510 - 09/13/17 07:30 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
SubieRubyRoo Offline
Loc: Winchester, Indiana
The two things close to my heart... Subarus and Pennzoil. Thanks for the good looking report!
#4515524 - 09/13/17 07:49 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
skyactiv Offline
Loc: The Midwest
Nice report. I'd like to see this viscosity become more popular with the WRX crowd.
Me: 13' VW GTI 3 door 6 speed manual
#4515562 - 09/13/17 08:31 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
Dumc87 Offline
Loc: Florida
Running this oil in my 2002 G20 with an SR20RR engine.
Seems to be good stuff! Would like to do a report, but the engine came out of a JDM import, so can't verify the actual miles. Supposedly 60k. Very clean and runs great, just not sure how legit my report would be lol
Thanks for posting!
'90 Z32 - PP HM 10w30
'98 ZJ - PYB HM 10w40
'02 G20 - QS UD 5w30
'09 Matrix - QS UD 0w20
#4515580 - 09/13/17 08:51 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
dblshock Offline
Loc: WI.
had you auto-crossed the 0/20?
16 Civic Coupe Touring
640:1 TCW-3 E091
Edge 0/40/XG7317
Firehawk Indy 500
06 4Runner SR5 135k
640:1 TCW-3
M1 0/40 XG3614
Falken Wildpeak AT3W
#4515591 - 09/13/17 08:59 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: dparm]
cueball89 Offline
Loc: NY
I was getting oil temperatures of 240f-250f while autocrossing, the corresponding oil pressure at idle was around 3-5 psi. I can't add an oil cooler to the car in the class that I run so I bumped up the oil viscosity. The Japanese service manual for this engine does spec up to 5w-40 for severe use. If I had a readily available non resource conserving 0w-30 oil at ~ $5 a quart I'd have run that. A light 0w-40 seems to be doing fine.
On a road trip to Lincoln Nebraska at 75 mph I got 30-33mpg and at 80mph+ I was getting around 28mpg with all of my autocross gear. The heavier oil doesn't seem to have affected mileage much.
#4515595 - 09/13/17 09:01 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: dblshock]
cueball89 Offline
Loc: NY
Yes, the 0w-20 had 4 or 5 events on it.
#4515912 - 09/14/17 09:07 AM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
dparm Offline
Loc: Chicago, IL
240-250 degrees isn't really that bad, I get hotter temps than that on the track with no ill-effects. The 0w40 is certainly working fine, I just think you could probably run something thinner.
#4516189 - 09/14/17 02:23 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
bluesubie Offline
Loc: NJ
Even though auto-x isn't as hard on an engine as track time, I would just stick with 0W40 based on the bearing issues that some stressed BRZ's have had. A friend of mine has a BRZ that's regularly tracked and it turns Motul 300V 5W30 into a 20 grade which is no easy task.
'04 Subaru Forester 2.5XT
Castrol Edge 0W-40
#4516795 - 09/15/17 07:28 AM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
mightymousetech Offline
Loc: Ontario, Canada
250F is normal operating temp on my 1er. Not really too hot.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4517569 - 09/16/17 04:35 AM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
KL31 Offline
Loc: South OZ
Viscosity firmly in the 40 grade range? Do I not understand something about how blackstone test the oil or did they just cock that up? Has to be over 12.5 to be a 40 last time I checked. It's firmly in the 30 grade range now (depending on blackstone measurements being accurate of course).
Staying at this grade seems smart seeing as the oil temp is high and the viscosity seems to be 30 grade. It's likely thinning to a 20 grade range or less due to heat in autocross (120 degrees Celsius approx). So it's no different (viscosity wise) to daily driving normally with a 20 grade IMO.
1995 MX-3 - KLZE swapped
Shell Helix Ultra 5W40
Wix 51356
#4519427 - 09/18/17 01:29 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
bulwnkl Offline
Loc: Arizona
What are oil temps and idle pressure now?
Non-political signature NOT removed
#4520133 - 09/19/17 09:31 AM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: bulwnkl]
cueball89 Offline
Loc: NY
I haven't checked them at an autox event since switching oil but on the street I got the oil temp up to ~235f and had ~12psi at idle. Some initial temperature, rpm and pressure data is below.
0w-20
temp rpm psi
195 2000 42
195 3000 60
195 4000 78
203 5000 78
205 6000 78
213 7000 70
0w-40
temp rpm psi
200 2000 50
201 3000 74
205 4000 83
208 5000 86
213 6000 85
217 7000 82
#4524933 - 09/24/17 02:52 PM Re: PP Euro 0w-40 2016 BRZ 5,278mi OCI [Re: cueball89]
subzerospeed Offline
Loc: Canada
Nice report. I used this for my last fill.
99' B4 RSK
Redline 5.40 & K&N HP-1004
Nitto Neo Gen's
Escort IX
Only braking for Ka
Page 1 of 2 1 2 >
