Yet another M1 0W-20 grade flavor!
by fdcg27
02/25/18 07:40 PM
The Winter Olympics
by BlueOvalFitter
02/25/18 07:23 PM
Enchilada casserole
by car51
02/25/18 07:21 PM
John Force Crashes at Phoenix!
by KneeGrinder
02/25/18 07:11 PM
Need floor jack that can use Pinch Weld adaptor
by MI_Roger
02/25/18 07:10 PM
The new Champ ST9688 is fat like the 3593
by slacktide_bitog
02/25/18 07:10 PM
Do you drink milk regularly?
by Reddy45
02/25/18 07:05 PM
What Is This Symbol?
by BlueOvalFitter
02/25/18 05:29 PM
Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
108 registered (Astro14, antonmnster, andyd, AV8R430, asiancivicmaniac, 2015_PSD, 11 invisible), 1782 Guests and 92 Spiders online.
64288 Members
65 Forums
278797 Topics
Page 1 of 3 1 2 3 >
#4515431 - 09/13/17 06:07 PM Generator shopping 10-12Kw considering Winco
FlyNavyP3 Offline
Loc: Jacksonville, FL
As the title states I'm shopping for a generator in the 10-12Kw range and currently at the top of my list is the Winco Tri Fuel HPS12000HE Linked here... for a standby generator for my house. I like that it uses a V twin Honda GX engine and although I don't currently have any gaseous fuel available I may look into installing a propane tank to have a reliable long term fuel supply. I want a generator that is overbuilt and reliable so far this seems to fit the bill. Generator will be housed in an enclosure that I will build next to my garage to keep it out of the weather and keep the sound levels manageable.
I'm certainly open to other options but the main reason I'm shopping for a generator of this size is to provide enough power to have AC in my house during extended power outages. This is the second year in a row that I've been without power for several days and I'm over it.
So guys tell me what else I should consider in a similar price range that will run my AC at my house as well as lights etc. not concerned about the electric range as I can use the microwave, water heater could also be powered by a 10-12Kw generator but obviously not at the same time as the AC but the water stays warm for at least a day so I can load share if needed to have cold air and hot water.
I'm not super excited about the Generac offerings in this size as the quality of their house built engines and generator heads seems to be hit and miss at best. I absolutely trust the GX630 Honda engine that the Winco uses.
Open to all opinions.
Luke
#4515454 - 09/13/17 06:25 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
2015_PSD Online   content
Loc: SE Texas
Is 10-12K enough to run your A/C (not sure what size your A/C is)? If memory serves, different fuels can produce different efficiency rates changing the required size of the generator. I looked at one a while back and I roughly calculated that I needed at least a 15K--I have a 3.5 ton A/C.
2015 F-250 6.7L Powerstroke Diesel.........Delo 400 LE 5W-40 + CQ Blue (WIX)
2014 Explorer 3.5L Limited...................M1 AFE 0W-20 + FU
#4515463 - 09/13/17 06:37 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
bioburner Offline
Loc: Minnesota
Having hot water when the temps are 8o plus is not much of a concern. A piece of black garden hose in the sun can make plenty.
Forgot what my friend got in Melbourne to power her home and well. I would say that a auto exercise feature is a must.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4515472 - 09/13/17 06:42 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
FlyNavyP3 Offline
My AC is currently installed with a 35A breaker the nameplate Amperage is 21.8A not including the air handler unit. The Winco makes 45A continuous load so that should be sufficient to run the AC. Prior to purchasing I will verify with a clamp on ammeter to ensure the unit will do what I want.
The Generator is de-rated 10% on LP and 20% on NG. In all likelihood I will just run it on gasoline as I don't really want to add a propane tank to my property. But a propane tank would add an additional fuel source for long outages without having to get gas from the gas station which would be nice. But I'd really want about a 200-350 gallon tank to really make it worth my while for the bother and expense.
If I wanted to go gaseous fuel only I'd probably buy an actual whole house generator in an enclosure, which I may still do, I'm currently exploring cost options. I'd like to be all in for $5,000 or less and I'm not sure I can do that with a propane tank and a standby unit in the 15-20Kw range which is what I'd need to run EVERYTHING.
Luke
#4515473 - 09/13/17 06:43 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
Blueskies123 Offline
Loc: FL USA
10K-12K will power a large window AC, refrig, TV and some fans. Maybe two small window AC.
It will not power hot water heater and central AC. You have to think thru how much fuel something like this will use for, as you say, an extended period.
My 6500 watt portable used 15 gallons a day if I run it 24 hours.
#4515481 - 09/13/17 06:52 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
eljefino Online   content
Loc: ME
If you have a propane tank what are the codes for securing that?
Vermont, in Irene, lost a lot of propane tanks that bobbed down the flooded rivers. VT is a radically different terrain and building codes are all over the place, but still...
#4515483 - 09/13/17 06:55 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
bioburner Offline
Loc: Minnesota
You can get below grade propane tanks
13 Scion Xb
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4515489 - 09/13/17 07:03 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
Balrog006 Offline
Loc: West Michigan
You might be unpleasantly surprised by what your AC or any electric motor pulls on startup, research "locking rotor amps", they can be as much as 3x nameplate specs and a standard breaker will allow this very brief spike on grid power but would be a no go on a genset
Is there a soft start kit available for your AC? This would significantly reduce the starting load and may allow it with your Winco
06 MDX 208K+ Mobil S 0w20, A01
08 CRV 262K+ VSyn w/ML, A01
04 JD L130 720H, Mobil S 5w30
13 JD 2032r 300H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
#4515503 - 09/13/17 07:21 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
WyrTwister Offline
Loc: Texas
To start a conventional A/C , the generator must be able to ride through the inrush current for the compressor .
Personally , I would look at the A/C name plate locked rotor amperage .
If you have a pretty new A/C using inverter technology for the compressor , a large part / most of this concern goes away .
How many rooms do you NEED to cool , as opposed to the whole house ?
Storing gasoline , especially gasohol , is not a trivial matter . And I am guessing , powering the whole house , is going to require more gasoline than you may think ? How many 5 gallon gas cans will you REALLY need ?
That is another thing about propane / butane fuel , sealed system . Much fewer problems with fuel storage or contamination .
Same with natural gas , but it is not unheard of , having the natural gas turned off by the utility . In times of natural disaster , to help prevent fire / explosions . We have a customer that found this out , after some earlier hurricanes .
I think you will find a diesel generator to be more fuel efficient , but , maybe at a higher capital cost . And diesel has fuel storage issues , just not as bad as gasoline or E10 .
And , will you be diligent enough to do the required preventive maintenance . Will you exercise it , maybe once a month ? Requires a personal commitment . A generator that will not start & run , when needed , was just a money pit .
Do not get me wrong , I would love to have a backup generator system . Just more $$$$ than I can do .
Best wishes , :-)
Wire
Wyr
God bless
#4515506 - 09/13/17 07:24 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
cronk Online   content
Loc: Watertown, New York
Take a look at Champion Power Equipment, they have been building up a stellar reputation in the RV community.
I own a 4000w for a home backup and a 2000w inverter for camping, have nothing but good things to say about them.
They make one with the wattage you are looking for but not multi fuel.
https://www.amazon.com/Champion-Power-Eq...pment+generator
They also got into the home standby unit market a few years ago
(this is just one model, they make several)
They engines in the Champion units are a made in China, Honda clone, but don't let that scare you, they are good quality.
Many on the Rv forums have many hours on them with no issues.
Champion also has great customer service, had to order an air cleaner cover to replace one that got lost, part price was cheap, and shipped from their warehouse in California, had it in a few days.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
#4515511 - 09/13/17 07:31 PM Re: Generator shopping 10-12Kw considering Winco [Re: WyrTwister]
georgemiller Offline
Loc: New York
I just purchased a Winco 12,000 used with less than 5 hours run time. I also have a Winco 9000 but wanted the larger 12,000 watt to run my central AC.
I ran 3 1/2 ton central ac and other appliances in the house on 2 separate test with no problem. The Winco at the time was also running off natural gas being fed by a 3/4" gas hose. The machine barely bogged down when central AC kicked on and if running off regular gasoline you will have no problem.
I also installed a 50amp outlet on side of house and have a 50 amp breaker at the panel.
Edited by georgemiller (09/13/17 07:33 PM)
#4515521 - 09/13/17 07:47 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
BTW, that Winco is a nice unit!
They have been around a while and are known to be good quality.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
#4515536 - 09/13/17 08:01 PM Re: Generator shopping 10-12Kw considering Winco [Re: cronk]
Loc: New York
Gillette also makes a nice unit but doesn't come tri fuel.
#4515540 - 09/13/17 08:05 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
madRiver Offline
Loc: New England
Have you considered buying a window AC unit to downsize the generator.
Fueling that beast may be an issue as these large inefficient generators have a voracious appetite for fuel that is not fun to get.
#4515576 - 09/13/17 08:46 PM Re: Generator shopping 10-12Kw considering Winco [Re: FlyNavyP3]
JHZR2 Offline
Loc: New Jersey
Diesel is the only way to go. Living off of one now in a real calamity.
Or else I'd manage my load so well that I could get by on a quiet Honda inverter generator. You'd be surprised what is actually important after a severe weather event, and it's not AC. Fueling logistics is most critical....
Page 1 of 3 1 2 3 >
