Amsoil and light weight oil
by Bullwinkle007
02/22/18 08:38 AM
What type of Dog Breeds do you own?
by pengem
02/22/18 08:30 AM
Calling AR guys - AR 10 Rear Sight options
by stockrex
02/22/18 08:00 AM
Alexa for seniors
by callbay
02/22/18 07:05 AM
229.51
by RogerBacon
02/22/18 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
02/22/18 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
02/21/18 10:47 PM
Rat: Trap or Poison
by WhyMe
02/21/18 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
02/21/18 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
02/21/18 09:41 PM
Serpentine Belt noise
by Tdbo
02/21/18 09:31 PM
Coolant Leak
by Ducked
02/21/18 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
78 registered (BAJA_05, 4WD, A_Harman, 2004tdigls, 2015_PSD, Andrei, 6 invisible), 1449 Guests and 101 Spiders online.
64253 Members
65 Forums
278525 Topics
Page 1 of 3 1 2 3 >
#4514990 - 09/13/17 10:16 AM Did KIA use 100% antifreeze from the factory?
boom10ful Online   content
Loc: California
I just tested the factory coolant just for fun with a Prestone tester. Instead of getting 50/50 the needle pegged all the way to the top. From what I know this stuff is just regular antifreeze, not anything special. Would this affect anything and is this something that I would take up with the dealer?
#4514995 - 09/13/17 10:23 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
ArcticDriver Offline
Loc: USA
A fsctory fill would not be 100% coolant, it would be diluted.
I would discuss with your dealer.
Multiple Diesel and Gasoline vehicles
#4514999 - 09/13/17 10:29 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
benjamming Offline
Loc: northern Alabama
Are you using a tester or ethylene glycol or propylene glycol?
#4515001 - 09/13/17 10:31 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
kschachn Online   content
Loc: Upper Midwest
Those little testers peg out at about 60% concentration don't they? That wouldn't be unusually high.
1994 BMW 530i, 224K
1996 Honda Accord, 251K
1999 Toyota Sienna, 387K
2000 Toyota ECHO, 264K
#4515002 - 09/13/17 10:31 AM Re: Did KIA use 100% antifreeze from the factory? [Re: ArcticDriver]
Kuato Offline
Loc: Colorado
Originally Posted By: ArcticDriver
A factory fill MIGHT not be 100% coolant, it SHOULD be diluted.
Fixed it for you....some weird stuff from the factory I wouldn't be surprised.
Thick vs Thin test: 15k / 43k miles complete
#4515007 - 09/13/17 10:39 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
Loc: California
I agree that these testers aren't very accurate, but from the factory it should be 50/50 no? Its an ethylene glycol tester; the ones that have a big needle inside. I've tested it on a premixed 50/50 and its right at the 50% mark. I've also tested it on pure coolant and the needle floats right up.
#4515009 - 09/13/17 10:41 AM Re: Did KIA use 100% antifreeze from the factory? [Re: benjamming]
mightymousetech Offline
Loc: Ontario, Canada
This. There are two types of coolant.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4515010 - 09/13/17 10:42 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
Sayjac Offline
Loc: The Old North State
Before having a dealer chat, check it against at least one other AF tester. I've used the inexpensive Chaslyn 5 ball AF tester and found it pretty accurate comparing to new Honda Type2 premix.
Doubtful it's more than a 50% AF concentration.
Edited by Sayjac (09/13/17 10:49 AM)
#4515011 - 09/13/17 10:43 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
Reddy45 Online   shocked
Loc: USA
Is it the green stuff? I ask because I did a coolant change on a friend's Kia recently and the OEM stuff was the darkest green I have ever seen. It almost looked like it was NOT diluted.
2015 Toyota Tacoma V6 4X4
#4515013 - 09/13/17 10:45 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
The long life coolants show very high on my testers even when properly mixed.
02 Wrangler super-s 10w30
87 F250 proline 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4515014 - 09/13/17 10:46 AM Re: Did KIA use 100% antifreeze from the factory? [Re: mightymousetech]
Loc: Upper Midwest
Sure. But are you saying the OEM KIA fluid is propylene glycol based? The MSDS says ethylene glycol.
1994 BMW 530i, 224K
#4515020 - 09/13/17 10:49 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
Loc: Upper Midwest
I don't know what the factory puts in for concentration, on my Toyota vehicles they recommend a 60% mixture and allow up to 70%. It's not a matter of accuracy (the tester should be fairly accurate) it is a matter of the upper range.
You could try mixing water with some of the coolant and see what that does to the measured concentration.
1994 BMW 530i, 224K
#4515045 - 09/13/17 11:12 AM Re: Did KIA use 100% antifreeze from the factory? [Re: Kuato]
Loc: USA
Thanks KUATO thumbsup
Could you describe further? I didn't realize there were any applications where 100% coolant would be advantagous.
Thanks for insight.
#4515053 - 09/13/17 11:17 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Yes 100% of a 40% HOH diluent
Edited by ARCOgraphite (09/13/17 11:20 AM)
2014 Nissan Rogue S CVT, OC#8 36109mi-MAGNATEC 5W30 + FRAM TG7317 Filter; 2017 Subaru Crosstrek CVT 4762mi-SOA 0w20 + SOA Filter
#4515072 - 09/13/17 11:35 AM Re: Did KIA use 100% antifreeze from the factory? [Re: boom10ful]
SHOZ Offline
Loc: Illinois
I would think factory fill would be closer to 60/40. 50/50 isn't good enough for the extreme cold of say Canada.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Page 1 of 3 1 2 3 >
