Originally Posted By: Dave9
Originally Posted By: OneEyeJack
A guy with a 2013 Ecoboost F150 stopped by to pick up a horse and we talked vehicles.
I just thought BITOG members might like to hear what someone is doing with their Ecoboost in a real working truck.
How long have you been a paid shill for Ford?
If that weren't the case, or if you didn't already acknowledge problems with ecoboost, then there would have been no reason for you to present this as you did.
You pretty much showed your hand and failed miserably. Please try to be less biased next time.
Wow, a little angry this morning are we?
He's got just over 200K miles and all of them with conventional Castrol 20w-50 at 5K intervals with Motorcraft filters. All his driving has been in the desert, high desert or mountains and mostly towing. He's had nothing done except routine maintenance. What he called 5w-20 oil can't be repeated here so I take it he prefers a bit thicker oil. He's had trips where he's towing maximum weight for 8-10 hours in the desert with temps in the triple digits and he won't risk his rig to thinner oils.
He also changes his air filter based on a delta gage and he's added a really big gas filter/water separator with a warning light and a coolant filter with a sacrificial anode along with an extra really big tranny cooler and a spin on filter with synthetic tranny fluid with a drain and refill every 30K miles. The diff also gets a heavier synthetic oil changed every 30K miles.
As hard as he works his truck I'd say he's doing okay with his changes.
I have to admit I'm a little surprised he went that heavy, but after thinking about it a 50-weight is a good choice for always high temps and always heavy use. I'm reminded of the Schaeffer Oil Million Mile van, 5.4L specified for 5w20 and they used 15w40 and had near zero wear. Seems like a 2 grade increase for super heavy duty works well.
All the posts about it being too thick at startup is from folks that may never have experienced the Southwest US temperatures....100°F at 6am...
