^^^ sure, but..... how far do you go in drinking the cool-aid, and how far do you go in verifying more yourself? On one hand, mfr guidelines are great against "you can't fix stupid," on the other, how enterprising is the same attitude which says, "I vote X because my daddy voted x, my grandpa voted x, so I vote x."?
I used to live in aggressively-driven streets but couldn't afford a nice car. I loved on and worked the snot out of my little 2.2L subaru wagon with 14" steelies. I got better tire wear going over the sticker, and better mpg. I watched temps -- ideally kept PSI at 2degree F increase from cold to hot, based on the tire engineering literature available at the time. I then worked on balance in cornering and found the car to balance the best when the fronts were 2PSI over the rears, which made sense since more weight was over the front.
Every single item in an automobile is compromised out of its own unique optimal design. Every single item. And compromise is established based on a set of perceived values. The margins are bound by big things like cost and safety, and then design requirements, and then finer points like customer expectations. It is ok to think, as long as you don't go outside of the bigger issues like safety.
Example. design an optimized gas tank. design for the most efficient use of materials for weight and strength. It will be a sphere. holds the most volume of fuel for a given quantity of materials, and will also be strong. But do you see any spherical gas tanks in cars or motorcycles? not a one. Already, its optimal design is compromised....
the s60 rides the best for me at mfr placard and the mpg does not really go up over that. 35psi. the truck +2-4 front, mfr spec for empty bed, +10 psi when towing heavy.
-meep
