Originally Posted By: ArcticDriver
Originally Posted By: spasm3
Originally Posted By: Noey
But, for a quick sear, it's not nearly as ideal as a carbon steel (Lodge, a favorite) skillet...it heats quicker, it distributes the heat as evenly and effectively as cast iron, and its far easier to maneuver b/c it's lighter.
I agree, I prefer to heat up my cast iron slowly, to avoid cracks.
Cracks in what?
Not the cast iron skillet?
I have never heard or seen this and I am not sure how it would happen since the material is expanding as its being Heated.
Cracks in materials typically occurr during a rapid cooling process.
Can you explain? Thanks
Yes, if you shop for old skillets, you will run across cracked ones. I'm not sure how it happens, i tend to think like you that it might be a hot skillet dumped into a sink of water. But still i heat mine gradually.
