Originally Posted By: Panzerman
I don't know where you guys are getting your information, just take a look at the Battle of Kursk to see the kill ratio of German tanks. The Sherman was useless against German tanks except for the outdated Panzer IV. Why they had to upgrade the gun in the Firefly Sherman's. It was noted as a Irony that the Sherman was called the Sherman who was so good at burning things because they often overheated and caught on fire and burned up.
German Jadgpanzer towards the end of the war was equipped with a 122 mm cannon that could shoot tanks 2000 meters out which was well out of range for anything Russian or American. The British and French tanks we're a joke.
Tell me how a Jadgpanzer was not a match for any other tank when it can hit you before you are in range, low profile harder to hit and faster.
At Normandy Two Tiger Tanks destroyed 22 Allied tanks in one firefight. So I don't know where you guys are getting this Sherman's were awesome.
They were cheap mass produced tanks that only won by sheer overwhelming numbers. They were high profile easy targets and death traps for the crew.
My whole point was the Germans should mass produced the Jadgpanzer because contrary to your beliefs it was a suitable tank v.s tank adversary and spent all the resources they saved on Tiger tanks for jet bombers and fighters which would have made a bigger difference. Look at tank battles statistics to back me.
Um, oh boy. The Sherman was named after a Civil War general like most other US AFVs such as the Lee, Grant, Sheridan, Jackson, and Stuart. You're referring to dark jokes referring to the Sherman as "the Tommie Cooker" or Ronson (lighter). The early Shermans had problems "brewing up" because of poor ammo stowage, the problem was largely solved with wet stowage using water jackets to dampen sparking.
A Sherman tanker was more likely to die from a landmine, artillery strike, or from German infantry using AT guns and Panzerfausts/shrecks than from enemy tank or TD fire...
The M-4 Sherman was primarily designed to kill people and to attack targets in the enemy rear, which it did very well with the 75mm "short gun" that fired an excellent HE round. It was upgraded with the deadly 17-pounder in British service and the Americans produced the final M-4A3E8 (76mm) HVSS version that was used into Korea and bettered the Soviet T-34/85 there.
Initially, the US relied on tank destroyers to fight tanks and actually wanted the Shermans to avoid 'slugging matches' of tank vs. tank battles. They grudgingly upgraded the Shermans with higher velocity guns and began work on heavy tanks such as the M-26/46 Pershing/Patton tank...
If French tanks "were a joke" how come the Germans used so many of them?
I think you mean the "Jagdtiger" actually, and it was a 128mm gun. Germany made a whopping 80 or so, against about 50,000 Allied tanks *****. They were complex, unreliable and absurdly expensive and a very stupid design actually that was simply a waste of resources...
But of course, the US had it's own silly tanks designs such as the T-28 Super Heavy Tank project. But we had to ship them overseas as we were winning the war. The Germans didn't have that winning problem of shipping things over the sea.
