Originally Posted By: mjoekingz28
Thanks for the sensibility Artem!
I will say it again, in my opinion, it is good practice to always check the oil level before and after an oil change. There is so much that can tell you. Where on the dipstick the level was before a drain cross-referenced to how much oil is drained. And of course the after, making sure you didnt pull the manual trans plug and fill the engine twice. Kill both the motor and transmission with one silly move.
Lucky for me, transmission fluid is red and it saved my car as it alerted me and may help mechanics at the lube shacks from making mistakes (or at least having the opportunity to not let them be costly ones).
I don't think anyone here is saying not to check the oil before or after an oil change. The topic is trust the "dipstick or the manual for refill capacity." As I mentioned I had a few vehicles over the years that had dipsticks that were off. So in order to get an accurate check after an oil change, or anytime for that matter you have to first determine the accuracy of the dipstick. IMO the easiest way to do that is get an OE filter and the amount of oil the owners manual calls for. Change the oil, let it drain for about an hour, install the filter, fill it with the amount stated in the owners manual, drive, park on level ground and check it the next morning. You can easily calibrate a 1 qt low situation as I mentioned earlier. Once the dipstick is dialed in you're golden, and you can trust the dipstick.
The manual for my car states 5.4 litres for engine plus filter 6.3 for dry engine. Where in the 0.9 lurking?? So how do you check the accuracy of your dipstick unless you start from a dry engine? By the way, oil expands when hot and my handbook states to check the level when hot.
