Originally Posted By: SteveSRT8
Not sure what you are talking about. Every vehicle I have seen including our 14 RAM has a system that is always directly connected to the wheels. pretty high effort (I pulled the fuse once) but always there no matter what.
Absolutely the most direct and accurate steering I have ever driven...
Well, that proves me a nincompoop!
Had thought the mechanical linkage had been completely done away with given EPS. Guess not - at least not yet.
Don't feel bad, I didn't even know it was standard on newer RAMs! tech moves fast these days...
Agreed, and actually, referring to the original post, if I recall there's another EPS system that does use hydraulic pump, cylinder, and fluid, just electrically driven.... so there's a lot out there to track.
