PumpPusher
Thread starter
Originally Posted By: merconvvv
Nothing but 820 here.
No sounds filter related atleast what i can tell.
You could change to another new 820 filter to see if noise goes away since u have a stash of these filters. Add .25 quarts to .5 quarts of oil as needed. The first start might be noisy but after that
If u still have noise change the oil to see if that makes it go away.
If u still have noise try heavier oil like 10w30 or blend of 5w20 and 10w30 if heavier oil is not your cup of tea.
Is the noise present on cold start after the car has been sitting around or even on hot start ?
I've been through several 820s and so far all have made noise, sooner in the OCI than the last. The noise is only present after the the car has been sitting 12+ hours.
Does not sound like the 820s is the issue. Sounds like your oil might be thinning out by 2k and draining to the pan overnite. It will drain out of the timing chain tensioner too if the gasket for that has a tiny leak.
I wud try 10w30 if warranty allows it and u r in summer time sorta. Some peoplen can smell the dipstick for fuel. I have not tried this particular test though !
This is where I am leaning. If the tensioners are leaking down, is this something that needs to be addressed? I need to add that I had a UOA good out to 7k and a filter cut open at 10k that didn't show any issues. There is a thread on it here.
