Originally Posted By: Kestas
I've been led to believe they reduced tension in piston rings to reduce friction losses. This allows more oil to bypass the rings.
Kestas,
low tension rings are certainly part of the problem.
Holden (GM Oz) with the 3.8 had problems in the early days...people were emptying sumps between services, when an Aussie would consider 1qt/3,000 miles as excessive consumption and worthy of a rebuild, and couldn't dream of running out of oil in 6,000 miles.
Holden changed the dipstick first, and the sump second, all to increase volume of oil ( the former essentially created an overfill...hmmm).
Per Honda
http://www.autonews.com/article/20131022...l-burning-claim
Kestas,
Per Honda
