229.51
by RogerBacon
28 minutes 41 seconds ago
One way to get the rust off under your vehicle...
by rollinpete
Today at 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
Yesterday at 10:47 PM
Rat: Trap or Poison
by WhyMe
Yesterday at 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
Yesterday at 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
Yesterday at 09:41 PM
Serpentine Belt noise
by Tdbo
Yesterday at 09:31 PM
Coolant Leak
by Ducked
Yesterday at 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
Yesterday at 08:44 PM
Avalanche front and rear diff change.
by spasm3
Yesterday at 08:40 PM
Abuse proof rental home flooring
by Oldtom
Yesterday at 08:17 PM
Low Noise Oil
by Ducked
Yesterday at 07:55 PM
2017 Dodge charger review
by gabriel9766
Yesterday at 07:51 PM
Dry reusable air filters?
by WillB
Yesterday at 07:42 PM
Batteries @ Menards
by Tdbo
Yesterday at 07:29 PM
Blotter Spot Test
by Emanuel
Yesterday at 07:22 PM
Is arming teachers the answer?
by ZZman
Yesterday at 06:45 PM
Another ATF question... I aplogize
by bardos
Yesterday at 06:12 PM
To Seafoam or Not?
by Marco620
Yesterday at 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
Yesterday at 05:50 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
61 registered (4WD, aquariuscsm, Armkb, 2015_PSD, alarmguy, 5 invisible), 1073 Guests and 101 Spiders online.
64253 Members
65 Forums
278522 Topics
Page 1 of 2 1 2 >
#4486856 - 08/12/17 08:48 PM Messed up something today
Rohan Offline
Loc: Tn,USA
I hook up the battery terminals in opposite direction by mistake today and now car won't startup at all, dashboard light not coming on, none off the electrical working.
I know how stupid I'm for doing this, was rushing to get rid off the car.
#4486860 - 08/12/17 08:50 PM Re: Messed up something today [Re: Rohan]
Rohan Offline
Loc: Tn,USA
Any advice what I should do first?
And sorry it is 2004 Nissan Maxima. The only thing come on is security light blinks. I hope I didn't blow the ecu up.
Edited by Rohan (08/12/17 08:51 PM)
#4486862 - 08/12/17 08:52 PM Re: Messed up something today [Re: Rohan]
Superflan Offline
Loc: Reunion Island
Check fuses?
4 years ago, I replaced chain & sprockets on a motorcycle. I was in a hurry and night was falling. A rear axle spacer fell and I didn't noticed it. I managed to put the wheel back and screw the whole thing in... bending the brake disc. What a mess. 13 years ago, I replaced a front brake system on my motorcycle. As I got interrupted in the process by some phone call or something, I forgot to torque the brake line holder (up the front fork sleeve). The day after, as I was riding, the holder moved toward the wheel, the tire cut the brake line and then I ended up crashing in a car tailgate at a red light (this or I was getting smashed while crossing the road). Two lessons learned: first, never do mechanic in a hurry, second, finish what you started before answering people or phone.
So, back to the question: check fuses?
Edited by Superflan (08/12/17 09:06 PM)
Yaris 1.0 197mkm, Kangoo 1.5 DCi 113mkm 15W40 ACEA E7
Wife's Koleos 2.0 dCi DPF eco-map 154mkm 5W30 C3
Varadero 125 92mkm 10W40 JASO MA
#4486865 - 08/12/17 08:54 PM Re: Messed up something today [Re: Rohan]
MadAmos Offline
Loc: California
I would hope the fuseable link or the equivalent failed before the alternator diodes or something even more expensive failed.
2000 Ford F250 7.3
1999 Miata
2014 Cadillac ELR
2017 Cruze RS Hatchback 6MT
#4486866 - 08/12/17 08:54 PM Re: Messed up something today [Re: Rohan]
danez_yoda Offline
Loc: texas
Check the fuses. Most automotive electrical circuits require some form of reverse battery protection. One form is a diode that only conducts when the voltage is swapped. This diode conduction blows the fuse to save the electronics,
#4486872 - 08/12/17 09:06 PM Re: Messed up something today [Re: Rohan]
The_Nuke Offline
Loc: Dallas, Texas
There a certain set of dash lights that should light up and blink/glow steady when you put the ignition into RUN (without starting/before starting). If those do not behave as expected, or if this blinking security light is the only response when putting ignition into RUN (before starting), then yes, you broke something that will need to be fixed.
Whether that 'something' is a fuse, several different fuses, a relay, a fusible link, etc. is something you will need to determine before you can move forward obviously. Start from scratch - unhook both battery cables and leave them unhooked for 15 minutes. While they're unhooked, test battery voltage. If it's good, then hook cables back up and turn ignition to RUN. Observe dash lights. Do they behave as expected, or is it still off-nominal? Proceed accordingly...
If you can get your hands on a Haynes/Chilton's manual for that vehicle, it will probably help you diagnose any electrical/ignition issues you might be chasing.
2010 Dodge Challenger
- Rallye Redline (3.5L+A5)
- 100+K miles (@3500/mo)
- Mobil Super 5K 10W-30
#4486878 - 08/12/17 09:13 PM Re: Messed up something today [Re: danez_yoda]
Superflan Offline
Loc: Reunion Island
And don't forget the ones one in positive battery lead, example:
#4486908 - 08/12/17 09:59 PM Re: Messed up something today [Re: Rohan]
The_Nuke Offline
Loc: Dallas, Texas
To the OP: whatever the problem ultimately turns out to be, please don't forget to come back and update this thread with the details and how you were able to identify it and correct it. I'm sure you will not be the last person to have this sort of thing happen, and when the next person finds themselves in a similar situation, being able to hit upon this thread with any searches and get the relative deets will certainly make their day! grin
#4486918 - 08/12/17 10:14 PM Re: Messed up something today [Re: Rohan]
mk378 Online   content
Loc: USA
Yes connecting battery backward will typically just blow the big "battery" or "alternator" fuse, cutting power to the whole electrical system, but no other damage. There should be a box near the battery with the large main fuses. They will be about 80 or 100 amp, and a special kind that aren't found in assorted fuse kits.
#4486927 - 08/12/17 10:26 PM Re: Messed up something today [Re: mk378]
The_Nuke Offline
Loc: Dallas, Texas
Originally Posted By: mk378
Yes connecting battery backward will typically just blow the big "battery" or "alternator" fuse, cutting power to the whole electrical system, but no other damage. There should be a box near the battery with the large main fuses. They will be about 80 or 100 amp, and *a special kind that aren't found in assorted fuse kits*.
Seems like those kinds of fuses are suspiciously close to the same size/diameter as various pistol cartridges aren't they? So much so that one might consider using a similar sized pistol cartridge for a temporary fuse in such a scenario, right? What's the worst that could happen... laugh
#4486958 - 08/12/17 11:47 PM Re: Messed up something today [Re: Rohan]
L_Sludger Offline
Loc: Ohio
Rohan, I would check the fusible links. I sympathize with you. I've goofed up terminals a time or two myself, but fortunately I never had any apparent ill effects from it. Knock on wood.
too many cars and oil combinations to list in 150 characters or less
#4486970 - 08/13/17 12:18 AM Re: Messed up something today [Re: The_Nuke]
FermeLaPorte Offline
Loc: Texas (south)
+1
#4486975 - 08/13/17 12:23 AM Re: Messed up something today [Re: The_Nuke]
L_Sludger Offline
Loc: Ohio
Maybe smart to use an expended cartridge case rather than a loaded cartridge. shoot tongue2 oilburner
#4486983 - 08/13/17 12:45 AM Re: Messed up something today [Re: L_Sludger]
The_Nuke Offline
Loc: Dallas, Texas
Me thinks there is some wisdom in your words...duly noted!! grin
#4486997 - 08/13/17 01:22 AM Re: Messed up something today [Re: Rohan]
john_pifer Offline
Loc: Nashville, TN via Memphis
Yep, you'll find a big fuse popped somewhere. I did this on my R1 motorcycle once, and it blew a big 50A inline fuse as well as one or two smaller ones. I feared the same thing you did - that I'd fried the ECU.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 198K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Page 1 of 2 1 2 >
