Originally Posted By: Linctex
Originally Posted By: bdcardinal
The system is set up to screw the dealer and the dealer employees over. ... there is a question that asks "Do you love your dealer?" if the customer does not answer "absolutely agree" the entire survey is a complete failure.
That's so wrong.
It's like these little electronic payment kiosks that have "tip buttons" that START at 20% & go UP from there!!
Sometimes.... I feel if the service wasn't worth 20%, then you should get no tip if that's the options....
I always tip in cash if I'm paying with plastic. So I select "zero" tip yet the server still gets rewarded, as that's whom I'm tipping in the first place. I am typically a generous tipper, as I've had jobs that relied on tips, so I feel good service should be rewarded.
Aside from solving your problem, it means the venue doesn't have control over tipping, reducing the amount given to servers by mandatory sharing policies.
That's so wrong.
