NJC
Thread starter
Originally Posted By: nthach
My parents have an 05 Sienna - I haven't heard of any weird sounds but should I plan on replacing these eventually? Should I even try to replace the bushings instead of the OEM arm?
I would advise against that, and here's why. Once the rear bushing fails, there's a considerable amount of twisting force upon the front bushing where it bolts to frame. Because I was concerned that this would be the case on my van, I elected to get a new control arm.
You would need a press to get the rear bushing out. I would get the OEM Toyota control arm, and check the ball joints. They make still be good.
