Originally Posted By: CrAlt
....You can screw the wrong canister filter on and have a major issue.
SAE/Metric lug/stud miss-match causing wheels to fall off.
Wrong spark plugs that meet up with piston
I am sure people could think of a few other common costly parts screw ups.
The wrong part is the wrong part. Mr cheap skate picked the wrong part.
MB's catalog system tells you the right part at the parts counter.
If he went to a real autoparts place he would have gotten the right part.
If he just let the kid at the QL place scan the vin and provide the filter he would have gotten the right part.
All valid points. The first, wrong canister filter able to be screwed on was posted not too long ago
HERE. A well known store quick lube was able to screw on an SAE threaded filter on a metric designed canister application.
Quote:
....I'd of thought it obvious...the old filter fits the new motor all to easily.
If it had been obvious 'to me' I wouldn't have asked the question so as not to waste your valuable time. Based on the condescending reply, in hindsight a poor decision on my part to make the query include a specific quote rather than asked as a general question using the OP's re: as reply name. A lesson learned for me here too.
I believe in common sense. 'IMO,' beyond not doing his due diligence in researching and selecting the correct cartridge, the owner didn't use common sense. As I've oft heard dating back to my high school days and holds true here, common sense is not so common.
