Originally Posted By: DerbyDave
The question about why the compressor is being replaced hasn't been answered. Did the pump shred itself sending debris into the rest of the system? Even if the system is properly evacuated and correctly charged with refrigerant and oil and no leaks are found it won't matter if the junk isn't flushed out first. If you don't know what you are doing don't just try to wing it and hope it all turns out ok.
+1
While we're not talking about Denso or Ford compressors that tend to send all sorts of shrapnel in failure mode, it's a good idea to check to see if there's any metal glitter or sludge in the hoses/lines leading to the compressor - debris on the orifice tube is a sure sign.
If the compressor was leaking and if you want to tackle resealing the compressor, you can buy a compressor reseal kit - you also need to get a "bullet" tool for the shaft seal so the seal lip isn't sliced by the compressor shaft.
+1
