Originally Posted By: FlyingTexan
I have a feeling my education level is far greater than yours so I'll just say it.... you're wrong and I could do my best to sink to your level and explain it or just let it go. I'm going to just let it go. I posted this because I wanted others to knownits a great product that I've found to be exceptional. Don't talk without knowing. It wouldn't instantly clog because it has a smaller filtration ability which would cause more resistance this the oil would generally follow the path of less resistance=the main filter. I have an engineering background and see no fault in what they've stated thus far. But keep talking I guess.
How exactly have you found their filters "exceptional"? The cartridge filters are clearly deficient in design, and we've also seen issues with the construction of the canister filters and the ADV. The company publishes no useful ISO filtration data, and has not responded to several requests for additional information from both myself and at least one other person from this board. So unless you have run ISO filtration tests and can provide the results, how do you make the statement that they are exceptional? What supported argument can you make that they do a better job filtering oil than does a Fram Ultra? Or even an orange can for that matter?
I too have an engineering background. The reason you see no fault in what they've stated is because they haven't stated anything that documents proof of performance. Kind of like the additive companies, if you make your claims nebulous and ultimately unprovable by the end user then you can't be held to any specific performance claim.
