- Joined
- Nov 29, 2009
- Messages
- 7,262
I retired this machine due to lack of power, but it turned out to just be a clogged exhaust port, so I decided for some dumb reason I was going to get it going again. It had been sitting, so I put a new carb on it a primer bulb a new fuel lines, then I put a new recoil on it because it broke. It hadn't been used in a couple years, but I got the carb tuned with no issues and thought I was good to go. I gave it a test on one yard thinking it was fixed, but then it started misfiring and didn't want to stay running unless you held the throttle down WOT. Im thinking it's the coil, but what are the chances it's just a bad spark plug? Why does it take 20 minutes for this to happen? Is it overheating?
