Originally Posted By: travlnman
Well, long time no post. As promised I finally made it back to report on my findings, however insignificant they may be
If you will remember, I can only get E85 from a station over an hour away, and don't get a chance to use it all the time. My biggest question was, if you remember, was the power increase strictly due to higher octane, or was there more to it ? Since my absence, many of you have chimed in (thank you) and provided lots of great information, but I was curious to see if it all played out in real life. The power increase on the E85 was obvious, but what about running only 93 octane in it's place ? My truck has run nothing but 93 octane since I ran the last tank of E85. While the 93 did seem to run better than 87...it was nothing compared to the E85 increase. Throttle response was down, trans didn't shift as quickly, just no comparison. In the interim, I also changed all my coilpacks and new spark plugs to cure a slight misfire at 115k. Just within the last week, I've had the opportunity to fill up on E85 for 3 tanks in a row and lets just say, my truck is a different beast again and I like it. BTW, it was mentioned somewhere about varying amounts of alcohol, and I think I mentioned (maybe) that the location I purchase it from only states a minimum of 51% required. However, I have the Torque APP on my phone, and one of the realtime data displays available is the amount of ethanol present in my fuel. It typically shows my local 93 octane has between 7-9% . After three tanks of E85, it currently shows my ethanol content at 74%....and purring like a kitten. I appreciate all the information everyone shared, and I hope someone is helped out along the way. Like I said in the beginning, I have no interest in political debate, this was intended strictly to share my thoughts and opinions...your mileage may vary
There are differing claims about octane rating of ethanol and E85. I've heard of everything from a (R+M)/2 octane rating of 100 to 114 for ethanol. E85 may have an octane rating of anywhere from 94 to 105 depending on who you believe. However, it's an adaptive ECU, so it will advance the timing as much as possible, which improved efficiency and top-end power.
