Somehow I made it to around 140k on the original thermostat & housing. I replaced just the thermostat because it was stuck open. Housing went shortly there after and was leaking. I had so many little things going. Towards the end of last year I was working on it every 2 or 3 weeks. Heater bypass pipe sprang a leak and was spraying engine shield, alternators, starters, ignition switch, water pump list is never ending.. I still needed motor mounts. Decided it was best to sell it and pay off part debt and get something with less miles. I've had three Fords & had to replace transmissions before 100k.
Originally Posted By: slacktide_bitog
Ford made a big mistake using the DCT in their Focus and Fiesta. They still can;t get it right after a dozen attempts to fix it. Why not just use a regular automatic?
The Focus SFE sedan with the 1.0T is availabe with a 6-speed auto. They should just use that on all automatic Foci. Maybe they can swap it in the next time they recall the DCT.
Overseas, the Fiesta is available with a 4-speed auto. Swap it in the next time Ford recalls their DCT Fiestas.
Originally Posted By: bradtech
Those Zetec engines would run forever in the Focus. Only problem for me was the rest of the car kept having constant problems after 80k. I had an 04 Focus and 06 Focus. Got rid of 06 after transmission failure at 89k. Even had it serviced at dealer every 30k. 04 kept going without transmission failure up to 155k when I got rid of it. But I was on my 3rd alternator and had replaced a lot of things. My 93 S10 has held up better than any of the Focuses. In my experience it seems those front wheel drive smaller cars just aren't put together that well. Including the Hyundai Accent I got now that has been at the dealer 4 times before they would replace what needed to be replaced. Only after getting corporate involved & an engineer/upper level tech going out to do it from corporate. I'm sure it will be scrap before this 93 S10 is.
The best part about the Zetec is the constant thermostat housing failure. It will explode every 30k or so
