Originally Posted By: SR5
Originally Posted By: SonofJoe
Do be aware however that a 5W40 light GTL/heavy PAO oil will very likely contain a sizable slug of VII polymer.
Would a light GTL and heavy Group III be possible ?
Probably not. About the heaviest Group III you can get is something like Yubase 8. This has a KV100 of around 7.5 cst. Blend this with GTL5 (with its KV100 of 5.0 cst) and you're left with a base oil mix that quite away from the KV100 of 12.5 min (more likely 13.5-ish once you take KO30 shear into account) so you would still need that big slug of VII.
