2005 Highlander with 142k well maintained miles.
The timing belt was changed at 96k, as was the pre-tensioner, the idler pulley, the belts, plugs, and the water pump.
Yesterday, I got out of the SUV to get something out of the garage. As I walked by the front-end (the engine was running) I immediately noticed the engine sounded louder than normal.
I popped the hood and isolated the noise to the area of the belts/pulleys (I think). I shut off the engine and checked the belts and tension, all of which was fine.
The "sound" seemed metallic to me and had me thinking "bearing."
I took the SUV to my indy mechanic and he agreed there was a mild but noticeable metallic sound.
Unfortunately, we both agreed the sound seemed to emanate from under the cam cover which is fairly close to the pulleys.
I made an appointment for two weeks from now. He's going to pull the belts and run the engine to see if the noise goes away. If so, that sounds like a cheaper fix.
If the noise remains without the belts on, he wants to remove the cam cover and go from there.
I have not seen any Toyota forum comments concerning any issue involving the cam with this vehicle.
Any thoughts on possible causes?
Thanks!
Thanks!
