Originally Posted By: SonofJoe
Wick,
I think you are putting 2 and 2 together and getting 357.
Yes, burning sulphur-containing hydrocarbons will form sulphur oxides, which, if condensed with water (also a product of combustion) will form diluted, weak sulphurous acid. It generally won't form metal eating concentrated sulphuric acid. Now traditionally, the biggest source of Sulphur for your engine has been gasoline itself. Today, virtually all sulphur has been removed from gasoline (I think the official limit is 10 ppm max).
Now a properly designed engine burns fuel and should NOT routinely burn oil. You should ignore those siren messages from certain OEMs that duplicitously start with words 'all engines consume some oil' because it's just not true. Anyway, regardless of whether engines do or do not consume oil, I would say that all base oil used in US engine oil, be it conventional or synthetic, is essentially sulphur-free. Just remember that in crude terms, base oil makes up typically 90% of a fully formulated engine oil, so even if you do burn some oil, the biggest constituent of said oil does not contain Sulphur.
Okay what about additives in oil? Well VII polymer is typically sulphur free as are Ashless Dispersants as are both Phenolic & Aminic antioxidants. So in rough terms, of that 10% additive in oil, 6% is entirely sulphur-free.
Now over-based metallic detergents like Calcium & Magnesium Sulphonates & Phenates do contain some sulphur but in absolute terms, this is two tenths of bugger all. So of that 10% additive, 6% is entirely sulphur-free and say 2.5% contains so little sulphur it's not worth worrying about. So we're roughly up to 98.5% of your typical engine oil containing little of no sulphur.
Which brings us to ZDDP which typical exists as 1% in finished oil. ZDDP is the biggest source of Sulphur in US engine oil. All ZDDP starts it's life a Phosphorus Pentasulphide (P2S5). You react this with alcohol, you lose one of the sulphur atoms (to H2S) and react the resultant Thioacid with Zinc Oxide to form ZDDP. ZDDP always contain four sulphur atoms and two Phosphorus atoms. Conveniently this means if you have 800 ppm of Phosphorus in a GF-5 oil, you will have roughly 1600 ppm of Sulphur there too. So that's a mere 0.16 wt% sulphur in an oil that you shouldn't as a matter of course be burning.
One last thing. When oil formulators talk about controlling acid formation, they are invariably talking about the carboxylic acids that can result from the oxidation of base oils. These acids are sulphur-free.
First of all thanks for that break down it is appreciated. Now I feel better,
my 5w20 Eneos is not a slouch of an oil with a sulfur content of .17 % . With great other numbers too .
I switch from Amsoil signature series after doing my homework. And this explanation of yours makes it confirmed
