Originally Posted By: kschachn
Originally Posted By: mightymousetech
Only thing you can do is to run fuel without ethanol.
I doubt that makes much difference either, we live in an EPA non-attainment area and RFG has been mandated here as far back as I can remember. All my vehicles have run on it since new as has all my OPE, the only E0 available is 15 miles away. I just don't see the issues some people seem to have with EtOH.
x's 2
My wife and I cumulatively have driven well over 700k miles in our vehicles- primarily on ethanol blended fuel- and surprise!, I think I've only put 1 or 2 pumps in.
This ethanol thing is like the "Pennzoil causes sludge" myth... it just doesn't go away. Next thing you know, it'll be the source of miscarriages, divorce, and lowered IQ.
More in the realm of reality, pumps can and do wear out. Brushes are the most common. Another huge contributor (here's lookin at you GM) is faults in wiring. A poor power or ground (mid 90's GM trucks had a braided strap that would rot away, which broke the ground path to the pump) will increase amp draw and eventually burn the pump up.
