Originally Posted By: oil_film_movies
Originally Posted By: Seventh
Sort of. It does have a sleeve at the bottom. Sort of like the W11 in your pic here but maybe one inch or so tall. The filter doesn't fit on it tightly. On the cap side, the filter just sort of snaps into it, on a little plastic "claw" that is integrated into the cap. That is how you align it, by snapping the filter into the cap and screwing it in.
Wow, I just learned a lot about all the variations in cartridge housings out there! On my old BMW 2008 530i, it was different.
Looks like dirty-to-clean direct leakage can't occur on the snap-in claw cap end, since it just stays snug.
On the other end, the ~1 inch sleeve on the other end may seal good enough, even if not super tight, since it should create a very small path for hot oil to leak through, of course talking about with the shorty (by 1 mm) Chinese oil filters.
If a plastic cage is there, sometimes that acts to align to the housing, and seal the first 2 mm to compensate for short filters.
Expanding further, if you look at the filters in my original post, they have sort of a sealing lip on the ends around the inner openings, which is responsible for sealing the filter dirty/clean sides. That would make the size of the filter critical, since it would be relying on a compression fit for sealing purposes.
Perhaps that is the reason for the zig zag pattern of the filter media, so it can be squished a little bit without being deformed?
