Originally Posted By: Nick1994
Originally Posted By: Wolf359
I would leave them alone. You can still have 2 prong outlets. Having a 3 prong outlet without a ground is against code. A 2 prong outlet is not. When the housing inspector comes and tests the outlets in my rentals, if they don't have a ground, they make me put in 2 prong outlets.
I can't believe I completely forgot they still make 2-prong outlets! My concern is the use of 67+ year old outlets and the risk of fire. Especially since one bedroom I may add a window A/C unit, just a small 5,000 BTU 4 amp max unit. With a new 2 prong outlet and an adapter it should work fine.
Around here they used to be as cheap as 3 prong outlets, but now that they're more rare, the price of them has jumped up, they used to be in the 50 cent range now they're over $2 each. Yeah the danger with an old outlet is that the springs weaken with age so it doesn't hold onto the prongs tightly.
