Terrible oil filters for Mini N1x engines
NorCal
I've been seeing a LOT of these "made in China" filters coming out of Mini Coopers lately. Cars equipped with N12, N14, N16 and N18 engines. I'm assuming these are coming from quickie lube joints because cheap.
Every time I pull one out, the remaining oil in the filter housing and filter cartridge cap are FILLED with metal particles. Literally looks like someone threw a handful of glitter in the oil. It makes me cringe. I never see that when removing an OEM purflux filter.
Upon closer inspection I found the China filters are roughly 1mm shorter than the OEM. I'm thinking they're allowing oil to bypass them due to the fact that they're short. The media looks decent enough, and I never see them torn.
I cannot find any branding on the filters. Even trying to look up the numbers on the filters yields no results. My best guess is Ecoguard X5830.
One review on Amazon complained that the drain plug washer provided with the Ecoguard X5830 is just a copper washer, instead of the nice silicon impregnated folded crush washer you get with OEM or other high quality filters. And it seems like that's what I see in conjunction with each and every one of these [censored] tastic filters.
Sorry for the weak pics, but I only have my phone to work with.
The China filter:
China on the left, OEM filters on the right. You can see that it's shorter.
I tried REALLY hard to get good pics with the glitter in the oil, this is the best I could do with my phone. Turned up the brightness with editing software so it stands out a little better... still doesn't do it justice. This is the inside of the cartridge cap. You can see the particles in the oil near the edge of the cap.
I know there's not many Mini owners on bitog, but I'm not on any Mini forum, (because I don't own one) and even though I'm not particularly a fan of Mini vehicles, this kind of thing really irks me, and I had to share. DON'T BUY CHEAP FILTERS!!1
Not saying these filters fit, but, assuming they don't, it still seems unlikely they can be actually putting this metal in the oil, unless they come with it from the factory.
I suppose if they don't take it out you probably would have secondary generation of more fragments, due to the circulating shrapnel, but I'd expect such bits would be smaller.
That seems to imply that, if this is a widespread observation, (a)there's something badly wrong with these engines, since jiffy lube/non-oem filters implies this is not running-in debris, and (b) the OEM filters should have quite a lot of metal in them.
Do the OEM filters have quite a lot of metal in them?
EDIT:
Re-reading I see above you say you don't see this with the OEM's. That's a puzzle then. Could the zig-zag pleat pattern be retaining it better, so you don't see it even although its there?
ENDEDIT
EDIT:
ENDEDIT
Correct. This is not running-in debris, although it looks similar. I see it on engines that are far beyond the scope of run in.
It is very strange. The filters aren't putting it there, my only thought is that they aren't filtering, and there is a sort of snowball effect of particle accumulation and wear.
It is ONLY with these cheapo filters. I've looked really hard at some oem filters and haven't seen any metal flake in them.
Thinking about it a bit more, if you consistently see metal in the Chinese filters, and you consistently don't see it in the OEM's, isn't the simplest interpretation that the Chinese filters are doing a better job than the OEM's?
(Again, assuming that they didn't come metal-filled from the factory)
I can see the "snowball effect" argument, (and mentioned something like it in my first post) but I think you'd need something fairly large to start such a snowball rolling, and I don't think that's typical.
My unscientific impression is that engines that are run-in and unfiltered don't normally have a lot of glitter in them.
I've only personally had unfiltered motorcycles, which didn't.
There are also classic unfiltered 4-wheel vehicles like the aircooled VW and the Citroen van but I've not had one.
I haven't taken any of the filters apart, but when looking at them real closely, neither of the filters have any obvious metal flakes in the pleats, only the oil does.
After I started noticing this many months ago, I look closely at the inside of the housing as well as the inside of the cap when doing oil services on these cars.
OEM filter = Never see flakes in oil
Chinese filter = Always see flakes in oil
You can draw your own conclusions on which you might prefer
Again, I don't own one of these cars, but if I did, I'd rather not see flakes in my oil.
Seventh, appreciate the pics & posting.
Those Purflux filters do appear to be the best, zig-zag pattern giving lots of filtering area, etc.
About the shortness of the Chinese Cheapies, does it really matter? I thought it was spring loaded. It rests on a spring, so any slightly (1 mm) shortness is taken up nicely. Am I wrong? This reminds me of my previous car, a BMW that has cartridge filters in a housing.
There may be a little cushy spring tension keeping it from rattling, but as long as the inside diameter of the oil filter itself fits over the metal sleeve below, and the cap's plastic sleeve, then no oil can accidentally bypass. ... Snug on tube aligner, then no oil bypasses. Length of oil filter doesn't matter that much.
Metal sleeve shown in the center of the housing (cap has a plastic sleeve like it which fits snugly inside the center of the oil filter too):
There is no spring loading feature for these filters. The only springs are at the bottom of the filter housing. The filter depresses two little spring-valves when tightened down. The filter itself isn't sprung, which is why I think the length (or lack of) is a problem.
The cap doesn't have any of the innards like a BMW does. And it (edit:) the filter (end edit) doesn't press tightly into the sleeve at the bottom of the housing.
Interesting. I shouldn't assume a Mini Cooper oil filter housing is similar in design to a BMW one, although Mini is made by BMW, and BMW outsources that housing to Mann-Hummel:
Some Mini Coopers had an alignment/sealing sleeve in the cap. Other ones had a fat rubber washer for it to rest against (with plastic cage which aligns it).
These are 1st gen mini
W10 and W11 engine
They fit real tight, and are not the engines I'm referring to here
The N series engines are somewhat of a Frankenstein build. Bottom end is BMW built, cylinder head is BMW design but built by Peugeot,and all the filter housings are made by Purflux. It says that right on them.
There is no alignment sleeve which seals? Hard to believe they didn't isolate clean vs. dirty side like that.
To mount the filter and align it seems difficult with no alignment sleeves in both cap and housing, as shown:
Simple answer: BMW/Peugeot engineered a lousy engine. Timing chains gone by 50k miles, DI carbon buildup, cooling systems made of sugar and plastic water pumps yay!!!
You're only seeing it on some models because only some engines are shedding metal. When they do the timing chain is usually to blame. I'd also bet the Chinese filter Minis are not keeping up with oil level. Engines burn it and 16k interval was a sorry joke. It gets low it eats timing chain.
Yes the bmw filter is nice. No to their rolled copper washer which sealed worse than a proper one. Always had drips using the rolled.
Fun car to drive. Lousy to maintain. Def like all bmw products lease do not buy!
BMW the ultimate (insert choice words here) machine.
Sort of. It does have a sleeve at the bottom. Sort of like the W11 in your pic here but maybe one inch or so tall. The filter doesn't fit on it tightly. On the cap side, the filter just sort of snaps into it, on a little plastic "claw" that is integrated into the cap. That is how you align it, by snapping the filter into the cap and screwing it in.
The little claw in the cap isn't great. On the N18 turbo engines there is a coolant line that runs right past the top of the filter housing, that you have to struggle to hold out of the way when installing.
If you fail to hold it out of the way far enough and just mash the filter in there, the filter falls off the claw, gets smashed in the housing all catty wompus, and doesn't depress the little valves at the bottom of the housing. Instant oil pressure warnings
Wow, I just learned a lot about all the variations in cartridge housings out there! On my old BMW 2008 530i, it was different.
Looks like dirty-to-clean direct leakage can't occur on the snap-in claw cap end, since it just stays snug.
On the other end, the ~1 inch sleeve on the other end may seal good enough, even if not super tight, since it should create a very small path for hot oil to leak through, of course talking about with the shorty (by 1 mm) Chinese oil filters.
If a plastic cage is there, sometimes that acts to align to the housing, and seal the first 2 mm to compensate for short filters.
In my observation, when it comes to cartridge filters it does 'seem' that OEM cartridges have a leg up on fit, quality and post use appearance. That said, in personal experience with cartridges for Hyun/Kia applications, Wix/Napa Gold were equivalent in those areas to the Mahle oem.
As for the "metal particles" anecdotes, not enough information for me to reach a conclusion that the aftermarket cartridge fit is responsible for that observation.
It definitely is a problematic series of engines.
This series of pics is from an N16, naturally aspirated. Doesn't have timing chain issues. Besides which, on the N14 (timing chain problem engines) it's the plastic guides that fail, not the chain itself.
99% of the owners don't keep up with the oil level. Cars come in with less than two quarts in the sump every day. Customers constantly come in saying "my oil change light comes on when I go around a corner." No, that's your oil PRESSURE light.
I still don't see glitter in the oil if they have an oem filter.
Ultimately, that's all it really is. An observation. I'm not claiming to know with certainty that the fitment is the reason I'm seeing the particles. It's just my best guess.
After paying close attention for many months, the only thing I can say with certainty, is that the cheapo filters always come out with the glitter in the housing, and the oem filters do not.
