Definitely repairable. Hit it with a torch and then quench it in hot oil when alls said and done.
Oil quenching of this is neither needed nor desired. It will only make the metal even more brittle than working it cold. I refer back to my previous post for concerns about making the wheel more brittle than it was.
If you're going to work the metal either do it cold, or if you do it with heat allow the material to air cool to prevent embrittlement of the base material through rapid cooling (quenching).
I was suggesting cold working it, and then heating it up and stress relieving with the quench with the gentle hot oil process. You disagree? Okay
The quenching is the part I disagreed with, both from an engineering and metallurgical standpoint both of which I'm trained in. Additionally as a trained aviation mishap investigator I've dedicated a lot of time and energy to understanding failure modes and post failure analysis.
Your understanding of quenching as a means to stress relieve a part is flawed. Quenching a part is actually the polar opposite of stress relieving the part which is generally accomplished by tempering a part.
You caught me before my edit. Yeah, I was way off.
