I had a 2013 for 3 years on lease, put 42K miles on it. We liked it but they have a design flaw that we couldn't live with as well as various quality issues so we turned it in at lease end. Under heavy load, IE accelerating on a freeway on ramp, exhaust gasses enter the rear of the vehicle through the vents that are under the rear bumper.
This is a well documented issue. Ford came out with a TSB which involves basically replacing the rear ventelation vents under the bumper with redesigned ones, a new seal around the rear hatch and sealing a bunch of body points with expandable foam. Didn't work on ours.
Even the new ones (2017) are reported to still have the issue.
Besides that the following issues developed in the 3 years/42K miles:
- Exhaust leak from rear head, ticking noise under load.
- Drivers side windshield washer nozzle broke inside the hood at the plastic connector.
- Rear bumper was uneven, had a gap larger on one side than the other.
- Sand or crud under the paint in a few areas ( this is a pretty common issue on these)
- The LED information display between the speedo and tach would randomly stay lit even with the doors shut and locked.
- The drivers rear seat release lever to fold the 2nd row up to get in the back was locked up, could only go through the passenger side.
- Windshield wipers wouldn't work on their fastest setting, they would just turn off instead.
This was our first Ford vehicle (reason for leasing) and quality was just, meh.... That being said. We did like the way it drove and the 3.5 is a pretty awesome power-plant.
If you are looking at a AWD model, the unit that controls power to the rear wheels is known to crack from stress and leak fluid all over the exhaust.
