1989 Merc 9.9 water entering lower cylinder
Waterloo, ON
I have a 89 Merc 9.9 That runs rough at idle and higher speeds. Lower plug always looks wet/grey emulsion and often small water droplets on.
Compression good at 105 PSI in both, gas is fresh and 50:1
New plugs installed, both getting good spark. (has aftermarket CDI box)
Carb (has carb from an 8HP) was taken apart and was spotless. Fuel needle/seat held pressure for 10 min, float set to 1 inch
Reeds appeared to be good and sealed tight
Float was good and main jet clean
Low speed jet at 11/4 turns out
I have replaced the exhaust cover gaskets and they looked fine, but still same issue. (I could see water in lower with cover off)
Is there any way for water from cooling system to enter the cylinder? I have heard lower seal can let water in, any truth to that?
These merc's have no head. Cylinder/head is all one piece, but if they had a head, the gasket would be the first place to look
Seems like a leak in the cylinder jug between the water jacket and cylinder somewhere, but like you say, the compression tests OK. It would have to be a minuscule leak that only crops up under certain conditions. Ugh..
The exhaust covers could be a place that might have a leak.
The cover over the exhaust could be rotted or cracked, the water jacket
cover over that cover would supply the water.
Though I'm more familiar with larger O.B. engines.
My 2¢
I have replaced the exhaust cover gaskets as mentioned in 1st post. The covers and the inside were pristine as a fresh water engine.
First image shows the gray water oil mix by lower exhaust ports
Use a straight edge to make sure that both plates are flat.
If the tattle-tale and the exhaust path are clear, there should be no
back pressure on the cooling flow.
Thats good advice, I will check them for trueness. I assumed that because they were so thin the clamping force of the bolts would pull the cover in tight even if they were a bit off.
Other sites have suggested the lower crank seal may be bad, but I cant see how that would matter, as that area is not exposed to any water.
True. The water has to come from the block itself, it's not under much pressure
and it should flow right back out normally. If the propeller is open and the lower
unit hasn't been worked on prior to the problem, I'd check the water outlets all the
way down to the prop.
My 2¢
Yeah, I've been to the dealer a few times. Parts guy only offers so much info, or only knows so much. Said 99% of the time its exhaust cover gaskets. I have re-seal the gaskets with loctite 518. I will pressure test the cooling system to see if the block is cracked. Not sure what else to do....
