Originally Posted By: PimTac
Something is being lost in translation over the interwebs so I'll leave it at that. Thanks for the explanations.
Nothing is being "lost in translation" Some things are being stated correctly (by, for example, me and barryh), some things are being stated incorrectly (by, for example, you and sonofjoe).
There are two separate, distinct, but similar and associated phenomena here.
1. Detonation
2. Pre-ignition.
You can either observe the distinction, and try and use the terms correctly, or you can relax, chill out, wave your hands about a bit, use the terms interchangeably, and maybe make up a few of your own that you think sound kind of cool and techy. Its very popular. "Pre-detonation" , for example, combines maximimum combination with minimum meaning.
Originally Posted By: SonofJoe
Classic knock (or pinking) is caused by pre-ignition of the fuel,
No it isn't. Classic knock (or pinking) is caused by
detonation of the fuel.
The octane rating of the gasoline is it's ability to resist pre-combustion.
I don't know if "pre-combustion" is a recognised term, but it seems a reasonable (if unnecessary) alternative name for pre-ignition, which is.
I do, however, know that the octane rating of the gasoline is NOT its ability to resist pre-combustion (whatever it is).
The octane rating of gasoline is its ability to resist
detonation, as operationally defined and measured in a special test engine. It will correlate with resistance to pre-ignition but it is not defined by it and they are not the same thing.
Here's an article that explains the difference in some detail.
http://www.contactmagazine.com/Issue54/EngineBasics.html
