Hey all,
My wife is currently driving her 2015 Subaru Forester 2.5 non turbo with around 46K miles on the clock. At around 30-Something thousand I started doing her oil changes for her, since I do them on my car anyways.
I use Pennzoil Plat 0w-20 on her car and go 6-7K between oil changes. I change the oil filter, oil, and drain plug gasket each time and do not notice any oil spots in our driveway or her parking spot at work.
About a month and a half after the oil change her low oil light came on by work, so she had to put in a full quart to bring it up to the full mark. Everything was fine until about a week before I was scheduled to change her oil again...same thing happened there. Full quart down the fill port.
When I changed the oil I made a note to check for any signs of leaks and I couldn't find anything. Everything was bone dry, no signs of oil leakage anywhere. Tail pipe area is clean and I don't see any carbon deposits anywhere.
I had read about some 2.5 Subarus having an oil burning issue, called the dealership and was told that her VIN does not fall in the range of cars that suffer from this. He did say something interesting though. "In the two years that I have been here we're had a lot of calls come in on this, and it's always with end users that change their own oil. I recommend you have your oil changed here and we'll monitor it".
Doesn't make any sense to me. There is the oil filter and the drain plug+washer/gasket.
Anyone have any ideas on what could be going on?
