Originally Posted By: SonofJoe
I wonder if in the future, oils will ultra thin (KV100 around 4 to 6 cst?) but that future engines will be fitted with oil temperature controllers (a) to rapidly warm up oil from cold and (b) to prevent the oil from getting so hot that its HTHS goes below a preset value. We have knock sensors to keep combustion out of the danger zone so why not actively manage minimum viscosity?
Of course this would mean the OEMs would have to get off their collectively bone idle arses and actually DO something (as opposed to abdicating all responsibility for anything to do with oils to the oil companies and AddCo's).
In theory I could see all sorts of reasons why this might be very desirable but knowing the OEMs, I'm not holding my breath...
they do that already: the oil and coolant systems are linked together: the coolant transfers heat to the oil during the warm-up stage, but the heat flow reverses as the oil gets warmer than the coolant. Most engines these days have those heat exchangers.
I am wondering if this an Oz thing? I had a good trawl through Google to look for stuff on oil/water heat exchangers. I see that some Fiat/Alfa Romeo engines came with such a system as standard fit. I also saw references to some VW & BMW engines having them as well plus one on a very old Jag. Other than that the systems seem to be more focussed toward engines destined for the track rather than the road. I also found a Backhoe mechanical digger with such a system (track days maybe!?).
I did find two rather good videos on YouTube from one of your fellow countrymen. He did a comparison of before and after fitting an oil/water heat exchanger. Here they are...
https://youtu.be/RGJqEgTjxKc
https://youtu.be/LRh7MRDi-XY
For me, what was interesting was that regardless of with or without the oil cooler, this guy struggled to get his oil temperature above 105°C and that's in a BRZ Subaru being given way more revs that I would give it (you have heard about global warming Down Under yes?). It makes industry standard tests like the Sequence IIIG and Peugeot TU5 look far too extreme and frankly a bit silly (they run at 150°C for upto 100 hours). My guess is this guy could run ultra thin oils and have very little by way of problems.
Any engine with a turbo is likely to have that now, and a good percentage of NA engines aswell. Only the smallest of the small, where price trumps everything, and the most sporty are exempt. The first wont have any oil cooler/heater, the latter will have a traditional oil to air cooler.
Will have a look at the videos, but I'm in the northern hemisphere, don't recall ever crossing the equator. But I've been close...
