Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
Is arming teachers the answer?
by ZZman
02/21/18 06:45 PM
Another ATF question... I aplogize
by bardos
02/21/18 06:12 PM
To Seafoam or Not?
by Marco620
02/21/18 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
02/21/18 05:50 PM
Castrol Edge 0w40 Formulation Change
by Tmaslar
02/21/18 05:41 PM
Another Brake Fluid Flush Question
by artbuc
02/21/18 05:19 PM
Preventative Care ?
by maverickfhs
02/21/18 05:14 PM
my best deal ever
by 93cruiser
02/21/18 05:08 PM
Motorcraft fl1a cut open 3yrs oci
by rollinpete
02/21/18 04:05 PM
Slapped my FilterMag onto a Fram Ultra
by ZZman
02/21/18 03:59 PM
Toyota OEM Oil Filters: 5 for $15 or 10 for $30
by NYSteve
02/21/18 02:37 PM
Need Oil Change Advice
by Fulgore
02/21/18 12:51 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
124 registered (AlaskaMike, 2003f7, 14Accent, 4WD, 2004tdigls, 901Memphis, 12 invisible), 1675 Guests and 96 Spiders online.
64253 Members
65 Forums
278514 Topics
#4431289 - 06/14/17 01:05 PM Best Fuel System Cleaner?
billt460 Offline
Loc: Glendale, Arizona
Is there even one? If so, which have you had the best luck with? I'm talking about the, "pour in the tank and drive", fuel system and fuel injector cleaners. I've heard Gumout Multi-System Tune Up is good for the newer engines. I know one can doesn't do much. Most people run several cans through before they notice a change. There are so many of these types of engine cleaners on the market, I wondered if one is any better than the other. Also, can any of them damage your catalytic converter?
https://gumout.com/multi-system-tune-up/
#4431290 - 06/14/17 01:14 PM Re: Best Fuel System Cleaner? [Re: billt460]
HemiHawk Offline
Loc: PA,US
I've searched and never found any real evidence that any of them do very much. Youtube wrench ChrisFix tested a couple with varying results, but most were unimpressive. I used Redline's SI-1 several times, no idea if it had any impact. On my old 4.0 Jeep it seemed to help with some pinging/stalling off the line but thats about it.
The one thing I've seen that was actually studied was the effects of top tier fuel on valve and piston cleanliness. Seems that has the biggest impact. It would work overtime of course, but it doesn't seem there is a magic bottle/can on the market that will do it in one tank anyway.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1997 Jeep GC 4.0
#4431303 - 06/14/17 01:24 PM Re: Best Fuel System Cleaner? [Re: billt460]
Hollow Offline
Loc: the South
If only there were an entire subforum dedicated to this very topic...
#4431331 - 06/14/17 01:52 PM Re: Best Fuel System Cleaner? [Re: billt460]
andrewp1998 Offline
Loc: MA USA
chris fix had good results with seafoam. i have seen decent results with chemtool as well
2001 Honda civic HX vtecE- 5 spd,224k+
#4431356 - 06/14/17 02:19 PM Re: Best Fuel System Cleaner? [Re: billt460]
OneEyeJack Offline
Loc: S California
The best means consistent, frequent periodic treatment. A little each time, not one big blast every now and then. This includes using good fuel and keeping up with the filter(s).
#4431361 - 06/14/17 02:23 PM Re: Best Fuel System Cleaner? [Re: billt460]
Tdbo Online   content
Loc: Ohio
I used to think not much, although I used a bottle of Techron at every OC.
However, I dumped a bottle of Berryman's Chemtool into the Ranger.
The truck now runs the best it ever has in the nine years that I have had it.
2012 Honda Accord LX-P 90K
2008 Ford Mustang Pony Package Convertible 16K
2006 Honda Odyssey EX-L 75K
2003 Ford Ranger 3.0 Supercab 102K
#4431379 - 06/14/17 02:40 PM Re: Best Fuel System Cleaner? [Re: billt460]
3800Series Offline
Loc: Gulf Coast, MS
Fuel system cleaner's don't do much. They have a purpose and I feel it's mainly intended for vehicles which where not properly maintained.
If your vehicle us running well the cleaner shouldn't make much difference but if it's some teens first car and it's running poorly or has a bad throttle position sensor it can help clean some of the build up caused by it running poorly.
9 times out of 10 if in using a cleaner it's on a car that is hard to start. It works well in this case. I remember when I bought our Regal a few years back. Car took 6-7 tries to start each morning.
After a quick tune up nothing really changed until I dumped a few bottle's of cleaner into the the tank. Since then it's started first try every time for nearly two years.
This is the most noticeable change for me.
#4431490 - 06/14/17 04:43 PM Re: Best Fuel System Cleaner? [Re: billt460]
NHGUY Offline
Loc: USA
ChemTool is one of the harshest chemical mixes you can buy.That said,I would use it sparingly and only when really needed.That being said I use it and have had some success with it.Seafoam is largely pale oil and isopropyl.I don't know why it supposibly works as well as it does for some people..its not aggressive at all.
#4431516 - 06/14/17 05:00 PM Re: Best Fuel System Cleaner? [Re: billt460]
TexasVaquero Offline
Loc: South Texas Rancho
IAM gonna use Scotty Kilmer's advice on this.( He has a phD in chemistry) and recommend techron if your car is for starters on good condition, if you need to get rid of water in your fuel.
He's said chemtool is very good as well as Gomout.
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
#4431609 - 06/14/17 06:47 PM Re: Best Fuel System Cleaner? [Re: billt460]
The_Captain Offline
Loc: Upstate S.C.
In my opinion any product with a good dose of PEA works well. Redline and Gumout both have PEA.
2017 Jeep Wrangler Unlimited 4x4 factory fill
First oil change will be Kendall Synthetic
#4431638 - 06/14/17 07:08 PM Re: Best Fuel System Cleaner? [Re: billt460]
CharlieBauer Offline
Loc: CA
Yep, PEA is a proven cleaner and at higher concentrations will perform a one tank clean up.
In lower concentrations, it will clean fuel injectors and in even lower concentrations, it will keep clean as it does in Top Tier fuel.
Costco had the additives in their top tier fuel tested and they have enough concentration to perform gradual cleaning.
If you use the one tank cleaner and notice no difference, that's good news! It means your system is clean.
PEA is a pretty generic additive so I buy whichever out of Techron or Gumout's one tank products is cheapest per gallon treated. But, I almost exclusively use top tier gas, so I only use it every 2 to 3 years.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
#4433068 - 06/16/17 07:52 AM Re: Best Fuel System Cleaner? [Re: The_Captain]
Virtus_Probi Offline
Loc: New England
The Gumout Regane products have PEA, and I think there is one other high priced Gumout product that also contains it, but it's not in the whole Gumout line.
Same thing with Techron now, there is a lower priced product in their line with little to no PEA.
2014 Forester XT, 75300 miles
Last Change;
Pennzoil Gold 5W30 d1G2
Tokyo Roki 15208AA170 filter
