Hi guys,
I have a 2003 Mitsubishi Diamante 6G74 that has a poor idle.
It feels like it misses a bit but not too horribly.
Idle quality is inconsistent. It ranges from smooth (rarely) to quite poor (also rarely) and usually is somewhere in the middle - Not horrible but not really acceptable either.
I have changed:
Injectors (these were cleaned and flow tested)
Distributor cap
Distributor rotor
Spark plugs
Plug leads
Fuel filter
Throttle body & ISC clean performed
Vacuum leak was performed - No leaks
Connected onto onboard diagnostic - No codes and all sensors seem to be reading within spec
Idle rpm are stable and where they should be
What would be the next thing for me to test/check?
As on rare occasion the car idles smoothly it seems that it is possible for it idle smoothly all the time.
Help would be appreciated!
I have changed:
Distributor cap
Distributor rotor
Spark plugs
Plug leads
Fuel filter
