Originally Posted By: Nyogtha
^^ Still don't see anything flat panel for me unmodified intake, Spanish, English, or otherwise.
Many people don't understand particle capture ratings. These can be expressed in a mass fraction / percentage. Larger particles weigh more than smaller particles, yet the smaller particles are what we want to filter out.
As usual for particle analysis, let's assume roughly spherical particles in the size range of interest.
A 9 micron particle will weigh 27 times more than a 3 micron particle, all else (including density) being equal; formula for volume of a sphere is ∏Rᶾ.
Use a cube with 9 microns per side vs. a cube with 3 microns per side if you prefer, the relationship is the same.
Both the CA and TGA are rated at >98% efficiency with the TGA targeting better capture of smaller particles, which is my particular interest.
And isn't that really what the OP was asking about in the first place?
No, he's suggesting what I'm saying is required, which is the replacement of the airbox with a Donaldson airbox. The only reason I brought up the Donaldson is its best in the business performance, however the already acknowledged caveat is that you need to modify your intake tract to accept their housing or one that utilizes their filters (which a number of the large HD diesel trucks use).
