Getting back to the OP's question, assuming you aren't measuring it yourself, I'd think you'll get fuel dilution measures as part of a UOA which will also tell you the viscosities.
The viscosity dropping below that specified by the manufacturer would perhaps be a reasonable basis for oil change.
In practice I'd think the lab supplying the analysis will probably advise you on this.
