Which port on the a500 a904 transmission is the output, and which is the return.
The port closest to front of engine is OUTput, or return?
I am adding a external mount filter deleting a magnefne, and making new steel lines and am standing here bending tool in hand while pan drains.
Will be doing a pan drop and filter change at same time. Today, soon, but need to bend these lines
and cant assume that my Magnefine was plumbed correctly anymore.
Guess I should see if Magnefine filter is dirty on inside or outside of element
