Originally Posted By: TmanP
Oil consumption is a fact of life for some engine designs. Half a quart every 600 miles is a quart in 1200 miles. Toyota says in their owners manuals that "acceptable oil consumption" is a quart in 600 miles, or twice what you're experiencing. I believe that GM's threshold is a quart in 1200 miles. I wouldn't call that a disaster by any means.
Ehhhmm, I just made an overnight 750-mile run in my '85 GMC with 32 years and 126K on all the seals and gaskets, towing a CJ7 on a 7K car trailer at 60-70 MPH, getting avg. 8 MPG loaded (around 11 empty on the return trip - just as an example of how hard the engine was working) and it burned less than 1/2 quart of oil... with leaky oil cooler lines and valve covers, and valve seals that allow a puff of smoke on start-up.
IMHO the only decent excuse for a modern, conventional (non-race, etc.) engine to burn more than a quart every 2,000 mi. is if it was abused terribly its first 10,000 mi. or run with less than 25% of its intended oil capacity for any length of time, yet it's fairly common in several widely-used engine designs from different manufacturers.
While unrelated to Chevy's 5.3 conundrums it doesn't help that even if the new owner does care to crack open the owner's manual there's basically no special break-in procedure (maybe, don't tow for a few thousand miles or something) stated. In the face of the idea of "no need for break-in" with my '13 Cruze, I changed the oil at 2K, 6K, and 11K, gave it 30 seconds to a minute warm-up every day for the first 10K or so, and kept it away from redline for about the same amount of time, and at almost 94K the oil level doesn't change over the 5,000 mi. OCI's. Maybe a fluke, but maybe some kind of break-in does matter.
