I am on a private well, its roughly 75 foot deep and is 40 years old. About 5 years ago I added whole house filters before the water softener and since the I have noticed a noticeable improvement in our water quality.
I usually change the sediment filter every 6 months and the carbon filter once a year. This time I ran them both a year for no reason in particular. Aside from water pressure that was getting fairly low at times and the sulfur smell in our water picking up a bit, I noticed no degradation in water quality.
I will probably stick with 6 month intervals on the sediment filter for water pressure sake.
The sediment filter is a Dual gradient Pentek filter, 25 micron outer and 1 micron inner media. Its about 12 bucks on amazon, made in china. The carbon filter is to help block smells, and It is a 25 micron filter.
It was a bit redundant to set it up the way I did, but I installed the system and figured it would give me a lot more options having a dual filter setup.
We use roughly 850 gallons of water a week, so these filters have 40k to 50k gallons thru them.
I forgot to take pics of the carbon filter, but it wasn't much different from the new one. The sediment gets most of the junk anyway, the carbon does seem to help with the waters sulfur smell.
P.S. I believe the black stuff on the filter is silt and sulfur.
P.s.s Yes I know Our well water is nasty. That's why by the time we drink it it has gone thru 6 filters, 7 if you include the softener.
