Originally Posted By: E150GT
did you change it because you felt like it or because you noticed anything?
I knew it had been 60k since I changed it last, and felt it was time to replace it.
Originally Posted By: pbm
That filter doesn't look bad for 60K.
What kind of OCI's are you running with the Synpower?
Any transmission issues?
I ask because I have a 2014 Focus...I changed out the OE air filter for a washable AEM Dryflow (no oiling it).
I've been running Motorcraft blend for the last 2 changes, 7k for the previous one, and 5k for this one (8 months, during winter, it was time). I'll probably run it for 7-10k.
I've had numerous transmission problems. Clutch pack has been replaced twice, most recently last September I believe, and TCM replaced once, plus several reprograms. It's been working mostly fine since the last clutch replacement, but we'll see what happens. I still have another 18k left on the extended transmission warranty, so if it starts acting up again I'm going to take it right back.
