Link
Shell is obviously going to appeal this but here are the highlights:
It appears the NAD seems to take issue with the comparative claims (like superior, unbeatable, etc) and that the stand alone claims are ok...
- NAD determined that the testing could not support the “unbeatable protection against corrosion” claim and recommended Shell discontinue the claim.
- NAD also recommended that the advertiser discontinue use of its image comparing corrosion on steel rods, because the image did not reflect the potential corrosion consumers might see in their vehicles in normal conditions when using competing gasolines.
- NAD determined that the evidence in the record did not support the advertiser’s claim that SVPN+ provides “superior protection from wear,” because differences in the advertiser’s laboratory test results could not be reliably linked to the real world performance of competing gasolines. (They use a modified HFRR diesel lubricity test)
- NAD determined that the advertiser’s use of an image of two intake valves, one with “gunk” and one without, was not misleading as long as it discloses that the image depicted test results from a port-injection engine on SVPN+ and a LAC gasoline.
