Originally Posted By: zeng
SAE paper(s) did suggest that majority of engine wear is corrosion wear, especially at startup and warmup phase or 'short' period after fully warm up phase.
They are influenced by among others cold oil (and ambient) temperaturess, some (or all) biofuels , fuels additive and engine oil additive packages, driving patterns etc.
However, with improved quality of current day fuels/oils and in relations to (localised) adhesion and abrasion wear,
I'm personally not quite worried about corrossion wear (which constitutes majority of engine wear) for the following reasons, namely:
a) they are not localised generally; and
b) where localised corrossion wear does occur , they are not at the contacting surfaces ; and
c) where corrosion wear occurs and localise at a certain pair of contacting surfaces (which I'm highly doubtful of ), it's likely spread out along the surface profiles of contacting components ........
such that all 3 scenarios above are not likely to result in changes in (measurable) components dimensions (in microns or a fraction of a thousandths of an inch) ---
hence, its (meaning corrosion wear) effect on reduction of engine components longevity is insignificant AND inconsequential , if any.
This quote is in referrence to the other thread claiming TGMO 0W20 as having 'lower' metal wear # vis-a-vis Mobil 1 0W40 as truth (which I forego contesting, for now).
